window replacement
- aaronbocknek
window replacement
still working on that issue. i am putting in a call to mr. weaver at weavers marine service today. ill keep you guys posted. did you read my latest post about the sea cocks? i talked with w/ edwards boat yard yesterday and bill bissell jr said that they can tow her over in march, haul her, put in new sea cocks and then relaunch her. hell, while she is out of the water, i might as well have the bottom painted. i would rather edwards take care of it than take it to intercoastal marine again. it might be more expensive at first, but, since edwards is a refit yard, i tend to think they will do a more complete job. bill said that he wanted the boat for a MINIMUM of 3 weeks out of the water to let the epoxy set properly. that is NOT the answer i got from intercoastal. they said it would ''be just a 4 hour job''..... hmmmmm what do you think?
I drilled a through hull for my Lectra-san in August. I used 3M FC 5200 and it cured up fast. I had it back in the water the next day. No leaks.
Eric
Looks like this:
http://www.drillspot.com/products/37497 ... ve_Sealant
you can get it pretty much anywhere.
Eric
Looks like this:
___________________
'83 Trojan Tri-Cabin "Manifest Destiny"
Build a man a fire and he will stay warm all day.
Set a man on fire and he will be warm for the rest of his life.
count brewski
Count Brewski, where on the Potomac are you located? Did we already discuss this? Thanks.
count brewski
just upriver from Nanjemoy Creek, right at the end of Md.Rte.6......you should be able to see my F-30 from the river, the channel runs close to Md. side where I am...... sitting on blocks on the hill, next to a small travel trailer and white farmhouse....I think we did discuss this before .......by the way, do you know how to post a pic here? I'd like to see if Aaron wants the mast I have on the parts boat..........arf-arf, CB
count brewski
