I'm working on cleaning out below deck and around the engines in my 1984 10M International.
The boat had a genny originally and the seacocks are still there. The wood used in mounting them doesn't look good. That area is always full of water. I think I may remove them and glass over.
If anyone can answer a few questions, that would be great:
-Should I mount the bilge pump along the engine room bulkhead, or toward the bow? The old pump was mounted right in between the genny seacocks, which are toward the bow.
-There were two wood supports and a particle board shelf mounted over the seacocks. I assume this was for the genny? Surprised to find particle board on the boat. The deck of the engine room, between the two engines, appears to be the same material. You can see it in the lower left of the photo. It feels sturdy and I don't feel any soft spots. I'm considering pulling it up to see what is under there and to clean it. Anyone know what is under there? Is it worth cleaning under there?
-The battery boxes were lag bolted with rubber grommets into the two stringers, the same place the engines are mounted to. The glass covered wood is in good shape. Is lag bolting with grommets the best way to secure the battery boxes? Of course I'll seal up any old holes with epoxy and make sure I seal up any new mounts with butyl tape or epoxy.
-Wire management. There was square plastic conduit box mounted in the engine room. I'm going thru the wiring and removed the conduit box and covers. They were full of years worth of dirt and grime. What does everyone use for cable management? Nicely zipped wrapped and secured? I see flex and spiral wire covers that are fire extinguishing online. I'd like to be able to inspect the cables and wires and to keep them clean.
Sorry for the long post! It's been raining up here a lot so I can't paint the bottom. Since I bought the boat last year I wanted to go thru the wiring and clean the engine room and engines.
Once again, thanks in advance!
