Teak deck (or more exactly the plywood underneath it) can be an issue if not properly maintained. Once you repair, Cetol will be your best friend to keep it sealed. If you are doing refinishing, don't use varnish on any deck surfaces - gets too slippery when it's wet.Barrie wrote:Bracebridge? how did you know that?
Great info, thanks a lot. The only parts I found to be really bad, was the back wooden deck and a couple interior walls that water has leaked into and swelled the wood.
License number on the boat 60 E 20141 tells you where it was last licensed. E means Ontario (they start out east with 'A' for Nova Scotia I think) then work their way west. Quebec is D. Ontario is E. Eventually BC is K. The number before the letter tells you which city the boat was licensed in. 60 E is Bracebridge. 18 E is Hamilton. 54 E is Toronto. The last numbers are a sequence number ... so your boat was the 20,141st licensed in Bracebridge.
This structure for license numbers is the 'old' style ... now they are Americanizing things .. you will see newer boats with license numbers like ON 56482 (ON for Ontario, followed by sequence number)
