Chaning the cabin door lock on 1990 12M International
I just bought the boat and I think I want to change the lock on the door. Has anyone done this yet. Can I just change the lock cylinder or do I replace the entire lock?
Re: Chaning the cabin door lock on 1990 12M International
Most times you can change the cylinder ( not sure your exact lock ) You can also have it re keyed
If it's a sliding door like on my '90 10M, it's nothing more than a patio sliding door lock. I went to lowes and bought a complete kit.
Sherman
'90 10m Midcabin
'90 10m Midcabin
My 10 Meter does not have a sliding door latch from Home Depot. Mine is broken and I would like to replace it, but I have no idea how to get it off or change the cylinder, neither does Bob at Beacon Marine. If you figure it out let me know. Good Luck.
===================================================================================Flyboy wrote:My 10 Meter does not have a sliding door latch from Home Depot. Mine is broken and I would like to replace it, but I have no idea how to get it off or change the cylinder, neither does Bob at Beacon Marine. If you figure it out let me know. Good Luck.
I'd wager that John Leed could help, or even have the part(s) needed
Don't want to highjack the post, but how do I get ahold of John Leads.
Check with Beacon marine (site sponsor ) he also can get what john has ( They deal with each other ) Bob is easier to get hold of
Okay,
I talked to Beacon Bob and they got the drawings out and they have no idea how to get the latch off either.
Will keep trying.
Will keep trying.
Can you post some photos ?
Usually you take the latch cover off and there are some set screws inside.
Here are some pictures of the latch on my 10 meter. I have removed the 4 screws from both sides of the latch but nothing comes apart, the plastic pieces just wiggle around.
I took your advice, took the lock off and gave it to a locksmith for a day. He rekeyed it for $20. He said it's a very simple lock cylinder.
I have the same lock on my '86 Mediterranean sportfisher and the lock no longer works (it's just stuck fast)...I can't get the lock out either. How did you manage to get it all apart? Thank you in advance!tcollins2 wrote:I took your advice, took the lock off and gave it to a locksmith for a day. He rekeyed it for $20. He said it's a very simple lock cylinder.
There were two screws on the inside of the door that I took off and that was it.
Did it look like the lock above?
