I used Dynamat Hoodliner in my engine compartment and it reduced the noise significantly ( http://www.amazon.com/Dynamat-11905-Hoo ... B00069QLVC ). It has adhesive backing which worked well. Just make sure to degrease thoroughly before applying.Captain Chill wrote:What in the hell... Looks like I have 100sq' to cover.
Went to the website to order 3 rolls of the 2'x72'x54.
Price comes out to $643.50. Pricey but I can live with it.
Put in my CA shipping zip code and BAM $897.00 to ship!!! Are they out of their mind?!? It's foam, I mean come on.
Do they not sell this anywhere else? Any advice DOUGNASH?
13 meter upgrades
- The Dog House
Re: 13 meter upgrades
- Captain Chill
Pricey as well. But it's a proven brand-name for sure. Says to use Dynamax Xtreme and then the hoodliner for best results. Did you do the whole cockpit floor or just above the engine. I'd love to see some pictures if you have them handy.The Dog House wrote:I used Dynamat Hoodliner in my engine compartment and it reduced the noise significantly It has adhesive backing which worked well.
'The Pacific Chill' - F26 -1976
- Captain Chill
Going with the Dynamat Xtreme under the cockpit and on the side walls.
Putting the Dynamat Hoodliner over the Xtreme on the hatch directly over the engine.
Will post results in my restoration journal. Thanks.
- DOUGNASH
Glad to see the forum is back on line
- DOUGNASH
- DOUGNASH
Exhaust is now hooked up from turbos to mufflers
Also connected the throttle, gear, and emergency shut-off cables
this will be sweet when done.
What kind of performance difference do you anticipate over the former engines?
Look'n good . Not trying being to be negative , but did you inspect the exhaust inside ? The reason I bring it up is the way its designed any leaking inside will get to the turbo(s) when shut down ,possibly worse . Just something to look out for as I would hate for you to have a issue after all this work .
- Captain Chill
- DOUGNASH
Well the 671's were rated at 450hp each but they were definitely not firing on all cylindersRWS wrote:this will be sweet when done.
These 871's are rated at 462hp
If I could get to a 18-20 knot cruise @ 1900rpm's I will be very happy
They should reach 2350rpm under load, so we will see what happens, I might have to re-pitch the props
My friend owns a prop shop, he was already totally disappointed I didn't have to spend big bucks on new shafts, I wasn't though lol
- DOUGNASH
I have been thinking about this a lotprowlersfish wrote:Look'n good . Not trying being to be negative , but did you inspect the exhaust inside ? The reason I bring it up is the way its designed any leaking inside will get to the turbo(s) when shut down ,possibly worse . Just something to look out for as I would hate for you to have a issue after all this work .
It's definitely a bad design
There are plugs on the bottom to drain out any water
I will at least change the plugs with ball valves to make them easy to drain
I also thought about putting a 12volt solenoid to the drain connected to the ignition, when the ignition is on and the motors are running, the solenoids will close, when power is off, they would open to drain any water
- DOUGNASH
Im taking it back, way back with these 2 stroke dieselsCaptain Chill wrote:Hell ya. This looks way future. Nice one.
More like "old school" than future
- DOUGNASH
Spent another full day on these motors
I put the intercooler back on and connected all the pipes for the cooling system
Also put in new thermostats
I have to pick up a few more hose clamps to finish
Those diesels are way cool
Something very "steampunk" about the copper exhaust
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
Hi Doug. Any Updates?
