onan generator
fpawn
onan generator
Post by fpawn »
Have a 6.5 Onan on my 1981 F32 and wondering if any one has rebuilt one and is worth the work. The last couple of seasons has not run. Any opinions???
Brooks
Re: onan generator
Post by Brooks »
You'll find that "It depends... ". Onan parts are increasingly hard to find, and when found are expensive. Generators have come a long way since then too, and a portable Honda on the bow may do better and be cheaper in the long run. Use this for whatever it's worth.
My story is actually good - the guy I bought the boat from didn't even know there was a generator on board. It didn't work at first, and when it did, it do so at 160 VAC. Adjusting the carb and slowing down the motor brought it into spec, then the sea water pump failed, $900 from the store, or $250 for an ebay rebuild? The ebay one is working fine, however MCCK impellers are $45 each. Pricey.
I know if mine dies again, it's Honda time - I think I've exhausted all the available parts, and the boat might benefit by not dragging around 600 pounds of seldom used generator.
Good luck in your decision
Re: onan generator
Depends on what is wrong with it . While Hondas are popular they are not true marine generators . Running one on the bow is very unsafe . About the only safe place would be on the swim platform if you have one . Any place else and your asking for fumes and carbon monoxide to get in the boat . still need to be careful on the platform .
Re: onan generator
Also, depending on what boat you have and where the generator is located, you may need its weight in the stern for ballast to avoid bow steering.
Re: onan generator
I have rebuilt two onan raw water pumps, in particular what is expensive is the bearing and shaft. I have posted on the board pictures and what bearing to purchase. Bearing cost $31 then $100 for machine work to duplicate what inside the water pump. My pully actual was wallered out so I bought a new 3 in and had a keyway cut in the shaft. Works perfect.
fpawn
Re: onan generator
Post by fpawn »
I don't use generator much, but like to keep it working.. I had it running up to a couple of years ago. If I remember , impeller was shot and such a pain to replace. Know any body in Boston area that knows these generators?? It is on a 1981 F 32
Re: onan generator
suggest you google terms together like:
PORTABLE GENERATOR
BOAT
DEATH
FATAL
CARBON MONOXIDE
read those accounts and do additional research
after some due diligence you decide if you want to risk your life and those you are responsible for.
....... once you do your own research, it's unlikely a reasonable person will go portable.
fpawn
Re: onan generator
Post by fpawn »
I agree with you on going portable and have no intention on doing. I rather get the Onan up and running
