compression fittings
Does anyone know where to buy the compression fittings used on the fresh water system on an 1987 f 36 ? also does anyone happen to have an old norcold 828 they re going to junk i need the T handle that keeps the 2 doors closed . thanks
If you are referring to the nylon/pvc type tubing, I got some from the local hardware store. Worked fine...
Danny Bailey
