The fuel line feeding the pump is about 12 inch long coming from the filter,(that is also mounted hard to the same stringer). The output of the pump is a hard fuel line that can flex, and is mounted to the regulator, that is mounted hard to the engin. Any help
Fuel pump
Fuel pump
Ok you all know that I am the dummy that mounted the electric fuel pump to the deck support stringer
. Now what do you think if I were to use rubber mounts to dampen the vibration sound. Do you think it could work harden the fuel line, and cause it to crack.
Info@emaltd.com
Info@emaltd.com
Thank’s Randy, The noise is not so bad under way, it is when you bring the engin back to idle it gets loud because of the bypass. I will be fixing the mounts today.
Info@emaltd.com
Info@emaltd.com
