Has anyone tried to remove the mirror in the head of a 1977 F-32? My mirror is getting cloudy around the edges. It appears to be glued in place. Removing the upper and lower supports is not enough. I'd not break is as I could use it for a pattern.
Summer Hi
Mirror Removal F-32
mr elevman
Mine are different as you have a port window in your head. But on my '85 32, I have no window but a vanity cabinet with two glass mirrors on either cabinet door.
Mine were fogging on the edges. I just took some wood trim and pictured-framed the outside of the mirror. Just measure, mitre and use construction adhesive to the glass and wood trim to add a custom touch to your mirror, then stain or paint to satisfaction.
Mirror Removal
mr elveman thanks for the wire tip. I forgot that did that to remove a car windshield.
It just happens that I was looking at how my mirror was mounted in my 76 f32 and found something unexpected while taking out more of the interior.
I dropped the ceiling that was held in by teak trim around the perimeter, and found the mirror is only held in by the lower trim and a upper teak strip screwed to the under side of the deck.
So the mirror floats in kind of a loose frame, I guess this keeps it from cracking when the hull and deck flex. I wonder if this is factory or if it was supposed to have adhesive holding it in?
Mirror Removal
Mac32, now you have me thinking. I didn't fully remove the top/bottom trim pieces--as the mirror seemed to still be solidly mounted. It sure would be nice if that was all that was holding it.
Lakeguy
Lakeguy
Mirror Removal
I got the mirror out today. After removing the top/bottom supports I found the top edge was held on with double backed tape. using a piece of flat stock I was able to reach up and loosen the tape.
Thanks for all the help.
