starboard engine vapor lock
capt ralph
starboard engine has been stalling when docking,changed fuel filters.........still doing it
capt christopher bouchard
Danny Bailey
capt ralph
vapor lock
thanks danny ,you may be right.my mechanic wants to replace throttle cables.he said that it couuld be idleing down to low to to slack in the throttle
The cables should not matter. The cable attaches to an arm. At the bottom of the arm there should be a low idle adjustment screw. The screw should be set to to maintain a low idle, even if you took the cable.
The other thing that happens is the low idle air ports on the carb get gummed up and blocked. The port is there so that when the throttle is closed (butterfly completely flat closing the the air intake), that enough air to maintain low idle can pass around through these ports. Some are set with lead, others have adjustment screws near the base of the carb. In any case, a can of carb cleaner with a straw generously applied when hold the engine at about 1500 rpm will normally clean them out.
I've collected a few gratuitus cocktails at the dock for having a can of cleaner in the dock box and a few willing moments to lend a hand.
Mitch
Mitch
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
capt ralph
