neutral switch
dean price
neutral switch
Post by dean price »
i just replaced my transmission cable on the strbrd 318 engine on my 73 f-31. but it won't start even when i jiggle the shifter control when in neutral. where is this switch located ? dean
Should be on the trans opposit the shift lever
dean price
neutral switch
got ya thanks dean
yorklyn
Post by yorklyn »
Dean,
You can check the switch by simply by by passing it. Just remove the two wire going to the switch and connect then together using a small bolt. If it starts its the switch, if not check the started. PS don't leave the wires connects, its a huge safety issue.
Good luck
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
