36ft Trogan tricabin new owner
Lee oakley
Post by Lee oakley »
I need information on a couple of things one is does anyone know what starter is in a 440 Chrysler?Mine on the Port engine is bad i removed it and there's no numbers on it at all! Going crazy trying to find a replacement lol. Next is at the gauge panel at the bottom are two warning lights it says stern what are these for or what does it mean when they light up? Thanks I am a total rookie guys please be patient!
Lee oakley
Re: 36ft Trogan tricabin new owner
Ohh it's a 1977 by the way lol
Have you checked with Bob Cushman from Beacon Marine? His phone is 609-713-4602 and he is a great help to the Trojan community!
Lee oakley
Thanks I see you also have 440s any chance you know what starters are in them? One of mine is shot either rebuild or replace problem is there are no numbers on it or any plate lol
I don't know offhand and the boat is 1 1/2 hours away. Call Bob!
Lee oakley
Lol okay I'm 10hrs away from mine so understand
fatman11
Post by fatman11 »
I'm knew to the forum and not sure if it is right to jump in here with a couple of questions from another new owner (also a 1977 Tri Cabin with 400s). Have worked my way thru most of the sytems and discovered how they work. Mystified by water system. Two key questions:
1. Is the water inlet the one on the transom insode the boarding ladder?
2. I was tole there is an outside hose connect for shower/wash. Can anyone tell we location and how to turn it on.
Thank you all. Great form. And I love this boat. :D
1977 36 Tricabin
400s
Robbic
Post by Robbic »
Hi,
I have the same model boat, I think.
The connection on the transom might be the outside shower connection. My boat has a water inlet thru-hull in the middle of the aft bedroom near the back, and a pump to feed an outside shower.
I do not have a pressurized water inlet. I have to fill the tanks, and use the built in pump and pressure tank.
