blower motor
- WayWeGo
Re: blower motor
By the time you are getting that noise, the blower motor is most likely ready to fail and oil will not repair the damage to the bearings. I would replace it before it fails and you are left without a working blower to vent the engine compartment before starting.
Re: blower motor
shortly after getting my 10 meter, and before the diesel refit my blower began its horrific death squeal.
I removed it and found nothing to oil - nowhere to oil
Drilled two tiny holed in it to deliver some oil
it got quiet
then, after one or more uses and all the trouble of removing and reinstallation, it passed on to the netherworld of dead and forgotten blower motors.
RIP FACTORY BLOWER MOTOR
In the end, it wasnt worth the attempted repair
Kinda like that girl you spend all that time wooing and romancing and when you finally "get some" it's not that good
Clearly, not worth all that work either.
Analogy?
PRICELESS !
it got quiet
Analogy?
PRICELESS !
