1983 f 26 cruiser head
I just purchased a 1983 f 26 and have to rebuild the shower in the head, does anyone have any pictures of what the original configuration looked like? Or one that was refurbished. I also noticed there is no drain in the floor, is this normal or was it maybe modified? Thanks.
Re: 1983 f 26 cruiser head
I have a 77 F26 so mine may have a different set up. On mine, there are two switches in the head, on the wall where the shower should be. One is fresh water pump and one is shower drain. The water from the shower flows through a channel in the floor and out to the pump and a thru hull on the starboard hull. I disconnected my shower because I haven’t used it in years, but I could hook it up again to the water heater and fresh water tanks. No pictures.
‘77 F26 HT Since 1999
