1988 11 meter has been running great! Until…. Late last season during an idle cruise, we had the Starboard drive start to howl. The howling was enough to actually feel it, and drop RPMs. Immediately put it in Neutral. Howling subsided to a very slight noise. Prop was still spinning as we were still moving with port drive. Made it back to the slip, and used the Starboard drive to dock. No issues. Rest of season to try and diagnose, it never did it again. Until now. I checked:
-both drives alignment. They are good.
-Removed and verified both raw water hoses to stuffing have flow, and the offending drive does have a drip.
- fluids in trannys good
- no wiggle on strut bearings (checked each fall pull out)
I did just order a temp pointer to check stuffing boxes when we go out again. Had a boat full both times it did it, so pulling carpet, and jumping down was not possible. It seems after letting it cool ( assuming it’s a thermal issue due to after letting the drive coast, it stops howling when re-engaged)
Anyone else ever have a wolf howling at them from below? Suggestions on causes? I am already planning on re-stuffing the boxes with the Kevlar/Graphite type stuffing.
Probably also replace strut bearings at fall pull as well. Recommendations on bearings?
Howling like a wolf!
1988 Trojan 11 Meter Express
Re: Howling like a wolf!
Good question. And I really don't have a good answer. I have to wonder about it coming from the transmission or even the engine? If still making the noise, will it do it in reverse? When increasing rpm? When you put it in neutral, it mostly went away. What about after you shut it off?
So being I had guests, I didn’t have time to ‘play’ with it, however, when I put it in Neutral, engine idled just fine, zero engine noises, just a very low growl/howl due to what I believe the offending prop still spinning since we were still moving. Like I said, after cruising on one for a bit, it would go into fwd, rev, N with no issues, and no sound. Busy this week, however will take it out with Thermo gun, an assistant, and see if we can recreate it and see if stuffing box, tranny, or???
Also look really closely at the engine for vacuum leaks. I have seen howling and whistling noises from carburetor base gaskets. And yes taking it in and out of gear will change the noise due to load and rpm change
This was a pretty loud howl/growl. If it were vac related, I would think it would do it right away, and have a very rough idle. I’ll report what I find in a week or so. I’ll sit and shoot temps while first mate putters around. If it is a tranny, I’m sure I’d feel it on the housing. It was bad enough last year to shake the boat a bit… Tranny does shift perfectly fine. It did not make the noise in reverse, but was not in reverse long either. Stand by: might be a week or two.
Update: Prior to fluid change, ran the boat strapped in the slip while in gear. Ran it for 1/2 hr. Shot temps and listened felt for vibrations or squeaks. Trans never got above 99, packing 89 ( water temp low 80’s), no noise. Cooler was doing its job, cool out, warm in for fluid.
Shut it down, sucked as much fluid out as possible, refilled with new. ( did both trannys after warm up), Took boat out for a cruise, Everything looks feels and temp checks all normal. Not a peep, not a howl. So, at this point packing seems fine, tranny seems fine, so I guess just needed some new fluid. The fluid I took out was a bit dark, so I must have some slipping going on, but not enough to get the whole tranny hot. Future pull and service in the future.
Good to hear, good luck.
