F32 soft spots on the fly bridge
has any body repaired those pesky soft spots on the flybridge ?? Im just getting into this job and am looking for some advise or pictures HELP!!!!!!!!!!!!
just for fun
I think some have had luck with drilling and injecting the holes with a hardner to stiffen things up. I personally do not know the procedure but surely someone will step in and help you. Good luck.
Get about a gallon of slow curing West Systems Epoxy (or equivelant cheaper stuff) and some thickening agent. Get a bunch of West Systems empty caulk tubes. Mix the epoxy and the "dust" to about the viscosity of mayonaise. Only mix enough to fill two of the empty tubes. Drill a 5/16 hole in the center of a soft spot. Shoot in both tubes with a caulk gun until the cavity is filled. Once the epoxy is cured, fill in the indent with gel coat or MarineTex.
- ready123
Re: F32 soft spots on the fly bridge
How big are they? If small then the prior suggestions will work fine.Mrsluggo wrote:has any body repaired those pesky soft spots on the flybridge ?? Im just getting into this job and am looking for some advise or pictures HELP!!!!!!!!!!!!
If large spots what I would do is cut off top fibreglass a few inches larger than soft spot, allow wet balsa core to dry, then CPES to treat dry core then replace topping with new fibreglass & nonskid.
http://www.smithandcompany.org/CPES/index.html
I have read about people who have repaired rotten stringers with this product... it is strong and protects the wood forever.
