Newbie Question- Oil Change on F25 318 Chrysler
Boaterguy
Post by Boaterguy »
I recently bought the boat, it is 3 hours from home, and I want to bring it home on the water. I would like to make sure that the oil is fresh before running it for the trip.
Here is the question- do I need to bring (ie buy) a pump to extract oil through the dipstick tube, or is the drain plug on the pan easily accessible on the F25 with the 318? If it is not necessary to buy the pump I won't- a penny saved.... :)
Please advise.
1975 F25
318 RH
Sea La Vie
buy the pump youll never get a pan under the plug plus you'll need it for the trans some time
LSP
Post by LSP »
Pump's the way to go
Will - LSP
1976 F32 "Donegal"
1985 10 Meter "Whakanui"
Hog Pen Creek
Middle River, Md
chucka
Post by chucka »
Warm it up before you try to pump out the oil. It thins out alot making it easy to pump. Also look for a pump with a stiff tube for the dipstick. The soft curly ones croll up from the bottom of the pan and only let you get out the top quart of oil.
formerly
Lots A Luck
Trojan F-26 Express
Narragansett Bay, RI
the best thing to do is to get a kit with a fitting and a hose for the drain plug . you will stll have to pump the oil out buy the dip stick to install it ,but the next oil change will be so much easier , I can pump my oil out in about 2 minites and I hold 15 qts per engine .
