i just put my enclosure on this week (pain in the azz), but it's not right, it appears. granted, the previous owner never used it, and it sat in storeage for years and years, but i thought it would fit better than it does.
anyhoo...the snaps are all lined up, etc. but the question i have, specifically, is how does the rear piece go into place? inside the rail or outside?
if i place it on the outside, the 'door' won't zip. if i place on the inside, i have too much slack in it, and it doesn't look right.
does anyone have photos of theirs that they can post to give me an idea?
thanks in advance
1977 F32 Bridge Enclosure Help
Tuck
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
Terran
(former 1977 F-32)
My back canvas goes outside the rails, when I use it and snaps on the over hang above the cockpit.
If the canvas was stored for any length of time, especially if it was folded (big no-no
) it will have shrunk up, and it'll be a bear to get on. Perhaps wetting it throughly then trying will allow you to get it on?
I think each set-up may be different, dependent on the fabricator.
you might try this if you will adjust the support arms or straps(not the pivots on the sides but the ones on the corners or the front 2 straps that clip to the boat by your light)that attaches to the boat for the bimini top it will allow the whole top to pivot thus raise or lower and this may be enough to make up for the difference of height needed to make this fit.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
