Motor question...1980 F36
- Struts and Rudders
I have just bought a 1980 F36 and need to get rid of the motors and are a bit confused as to the manufacturer of the current motors.
Here is my question...The motors have chrysler exhaust manifolds but seem to have ford intake manifolds. Are they Ford or Mopar?
I will be selling the marine items from the engines ie..heat exchangers transmissions, manifolds, starter etc.
...the motors will be rebuilt as engines for vintage drag racing.
Thanks,
SRD
Thanks,
SRD
In 1980 Trojan used Chrysler or GM's or Deisels. Not Ford. You need to read the '10m repower' thread cause engine rebuilds/replacement was just covered there. I will say no more for now.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Maybe fastestonehere will buy them and turn them into 1,000 HP each
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
YES the did offer it with Ford engines
What you have is 460 fords they where use by Chrysler marine .
when the stopped making the 440 the started using the ford 460 block.
many trojans used these . they are hard to get marine parts for them
Recc you buy a ad in the for sale section someone may neeed parts
Thanks for the info and the warm welcome. I am a proud new owner with big plans to cruise the coast of the Carolina's and Virgina.
Does anyone know how much horsepower they made from the factory?
I am going back with 6.0 MultiPort fuel injected Chevy's that produce 375hp and will weigh quite a bit less than the current engines.
I want to make sure that I am not backing up by putting a lower horsepower motors back in the boat.
F36 1980
"Cope & Drag"
SRD
F36 1980
"Cope & Drag"
SRD
- alexander38
I don't think you have to worry about that
- alexander38
O and welcome in hope your stay is long and fun. Where's your Homeport ?
Our 73 F36 has GM 454s. New rated at 330hp (not likely there anymore) but it still jumps up on plane and will do about 30mph although we spend about 90% of our time running about 10-12 mph and use 1/4 of the gas to go the same distance.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
- alexander38
Don't we all.
- alexander38
Don't we all.
