Hoping this works
Hoping this works
Trying to post pic's one more time. Most of them was from doing the teak in the Salon, Saloon?
http://s1110.photobucket.com/albums/h448/ReelClass/
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Miss piGGy
Scrubbed everything with Clorox 2 and let dry. Had to scrub more than once to get the finished look I wanted. When I got the look I wanted when completely dry then I put three to four coats of Teak Oil on it. Took some time but got it the way I wanted it. Lot of hard work, and NO the clorox2 didn't stain the carpet at all.
Looks GREAT Allen
What do you use to scrub with ??
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Miss piGGy
- alexander38
Well I'd have to say those meds worked
I just used a small scrub brush and a toothbrush in real tight area's. Nothing real special. The real trick was having the patience to let it dry completely to see if I had the even color I wanted. Getting those water stains out was a PITA!!!!! Of course now I have the interior torn apart again ripping out the water tanks. Just another thing on the list! Unepected list not the planned one!!rbcool wrote:Looks GREAT Allen![]()
Ron
- Struts and Rudders
Nice work.
I am about to start something along the same lines and have looked around quite a bit and found wipe on poly from minwax to be easy to use and provides a nice satin look without the tacky feeling left behind by teak oils.
I removed and sanded a grab handle and followed the directions on the can and the result was great. Nice even finish and seems very durable.
SRD
1980 F36
Cope&Drag
SRD
1980 F36
Cope&Drag
Did all that b-4 boat was hauled for winter. Was off work w/ broken arm at the time!alexander38 wrote:Well I'd have to say those meds worked
- alexander38
Good to here you're doing well. Ribs it is then in July
