trans vent overflowing
On my buddies F-32 GM Crusaders 270hp velvet drives, when the trans fluid is full to the mark, while under way, trans fluid comes out the vent, after approx ten hours of running the trans fluid is a quart low, refill to the mark on the stick and after another ten hours, another quart low. Does someone know what or why this is happening?
1975 F-32 "SIMPLY BLESSED"
I agree with Gumper. Most common mistake. The only other thing I can think of is water in the oil or perhaps running too hot due to insufficient cooling. Temp gun would really help here.
I finally got a chance to look at my buddy's trans and while the engine is running all the trans fluid is pushed out the trans vent within an hour. I watched it happen. Do you think it may be caused by a plugged trans cooler creating back pressure? It did not do this until he had the engine rebuilt by a marine service. They removed the trans to rebuild the engine and replaced the trans when they put the motor back in. By the way, that marine service is now out of business. Could they have hooked hoses up wrong or backwards? I'm stumped.
I would look at the vent If the check valve in its bad it cause the issue , I did not know it had a valve untill I got a new one a few weeks ago .( broke the old one pulling the trans out. they could have damaged it when the worked on it.
OK, so I'm trying to figure out how that would change anything! As long as the oil lines are hooked up to the oil ports on the cooler why would it matter the position? They aren't directional...are they? Does anyone have any insight on this?
I guess that explains why they went out of business.wowzer52 wrote:I found it! The hoses to the cooler were hooked up backwards. Changed them to match the other engine and everything is fine. The marine service that did the work on it obviously needs some schooling.
http://www.cbyc.ca/
http://www.cbyc.ca/
Having just had my oil coolers off and cleaning them, I cannot see flow direction of the oil making any difference. If you look in at the end of the cooler it looks like the header on a boiler only smaller. That is a number of pipes that to straight through. Some thing could have stopped up the oil line and when reversed it cleared?
On most coolers it should not mater .Big D wrote:OK, so I'm trying to figure out how that would change anything! As long as the oil lines are hooked up to the oil ports on the cooler why would it matter the position? They aren't directional...are they? Does anyone have any insight on this?
