let the repower begin
gettaway
Post by gettaway »
I pulled the engines from my F32 last monday, have spent every moment of free time trying to clean up 30 years of crud in the bildges. I scrubbed the entire engine room with orange cleaner and then soft scrub yesterday. I should get her painted before the weekend.
What am I repowering with you ask? well, I bought a matched pair of mercruiser 165, GM 250 inline 6 cylinders and a pair of twin disc 502's.
The mercruisers have just over 400 hours on them, long story but they were bought new by a guy in Airzona, who, after 7 years of ownership passed away. The wife held onto the boat unitl thie year and gave the boat away to the gentleman I bought them from.
The engines run perfectly and the twin discs came with the correct flex paltes and bell housing adaptors. 140psi (+- 2-3) in all cylinders
Image[/img]
ImageImage[IMG]
gettaway
Post by gettaway »
the old 228 mercruisers pulled and striped
The "New" mercruiser 165's, Note, that is dust from sitting, there is not an oil leak, spot or spill to be found.
fpawn1
Post by fpawn1 »
I re-powered a couple of years back and only wished that I repainted the bilge at that time. I saw a picture of one that was painted. Not sure if you would be better off using an epoxy base paint, but I am sure there are people here that are more knowledgeable
Wow...one thing I notice is how far forward your engines sit than mine do!
Good luck and keep us posted on the refit.
gettaway
Post by gettaway »
Striperman,
really, our engines are in different locations? what type of transmissions do you have.
After a lot of measuring, it looks as if the inline 6's with the twin discs will actually sit a little further aft and I'll have a littel more room between the front of the engine and the bulkhead.
Ok I have to ask WHY ???
The bell housings off your V8 s will fit the In line 6 .the front engine mount , will some how have to be supported by the strings , but that should not be hard.
Well...from the looks, your shafts appear to be longer. I know...there's a joke there. :-)
My engines have more room between front and bulkhead. Same Chevy small block footprint with BW velvet drive. You have what appears as no room up front! I'll check measurements this weekend...
Paul is correct on the bell housing as well.
Jamie are you ruining a 1 to 1 ? I also don''t remember seeing a F32 with engines that far forward.
gettaway
Post by gettaway »
heres a few photos of the 165 after simply cleaning them and installing a transmission. I did prime the transmission and I will be repainting the engines, I am having new mercruiser decals made for the engines
looks good
pk
Post by pk »
Ooo......All looks very good! But WHY don´t install diesels?
prowlersfish wrote:Jamie are you ruining a 1 to 1 ? I also don''t remember seeing a F32 with engines that far forward.
I believe my trannies are 1:52-1.
pk wrote:Ooo......All looks very good! But WHY don´t install diesels?
pk
Post by pk »
..... and me who thought all you Americans were rich people.... :wink: A couple of diesels, used but in good shape can not be more than 10 Grands?
