Fresh water tanks
Fresh water tanks
Can anyone see a problem of using NEW FOOD Grade 30 gallon barrels for the fresh water storage on my F28. Currently it has round ones that are of course galvanized 30 gal each about the same dimensions as the Barrels. My thought is that the plastic barrels are certainly tough enough and sanitary enough and the two bung holes can be adapted as needed.
Oh Yes the price is right :D :D [/u][/b]
g36
Post by g36 »
i know tanks can cost but have you looked on ebay. my friends just bought to new 30's for a great price compared to new.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
k9th
Post by k9th »
Sounds to me like you already have an existing galvanized tank and are wanting to replace it with an appropriate plastic tank of about equal size - I was a bit confused by g36's answer.
My only concern would be pressurization. Do you use your on-board fresh water pump to pressurize the system or do you use shore water connected directly to the boat? My system bypasses the tanks when I am connected to shore water but I am not sure they all do that.
I would determine the pressure of the system you are using and make sure the tank is rated for that pressure with a safety factor of at least 2.
Other than that, I see no issue as long as it is supported properly and plumbed correctly.
Yep I already have two 30 gal tanks galvanized one on each side of the boat. They are not pressurized, that occurs after the pump and the only source of water is the tanks filled from city tap, unpressurized and with overlfow.
I do intend to pressure the system but will have a valve to protect the tanks from city water or pressure tank water. If it check valve were to fail back up would only go out overflow anyway.
The reason to use the barrals is they are round and will fit exactly where the old galvanized ones were, most new ones are cubical.
Now gas tanks is a different thing and will use certified replacement my get aluminium as they will be round also, but that is for another day.
I do see any problem with using the barrels myself.
K9th, tanks aren't pressurized, at least not in recreational vessels that I'm aware of.
When using dockside water, the check valve in the water pump will prevent the water from going into the tank. Having said that, the built in check valve on water pumps tend to fail quicker than an in-line unit that you can add to the line after the pump (pressure side).
Hope you can rig fittings to the barrels that will not leak. I think that will be your biggest challenge.
gettaway
Post by gettaway »
whats the worse that can happen, the tanks leak and the bilge pump pumps out the water. you are already carrying the wieght, it wold ruin a weekend without water, but not a boat sinker
Not a boat sinker but deffinately a nuisance....reffer to "water in bilge" threads!!
Allen Sr
Post by Allen Sr »
I did that on my F35 but I used the 55gallon ones. Minor modifications for me to install cause I went to a larger capacity but have had no problems at all. For the vent I drilled and tapped the tank and they work perfect.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
