Considering Purchase of 10.8 meter
I am looking at a 89 10.8 meter convertible. Another potential buyer had a survey done, and they found rot in stringers under the cockpit and in an engine room bulkhead, which supposedly came from improperly installed scuppers. This is being repaired now. Can a follow up survey tell how well the repairs were made after its all put back together? Also, is this a common problem on this model? The rest of the boat reportedly surveyed ok, but what other things should I look out for with this model? Do thesae boatd have cored hulls or solid fiberglass? Thanks!
JuiceClark
So many good ones on the market...
There's a great boat on every corner in this market. I wouldn't dig-in too far without looking around for another. I don't know where you live, but look at this:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0099286191
It's hard to tell if someone did a good job on stringers...who knows how they did it. If all the wood isn't well covered in expoxy, it could happen again.
Any boat manufactured with wooden stringers has the same susceptibility to rot.
Some Trojans, especially the F series, have a fairly flat hull from midships back. This allows a relatively small amount of bilge water to be in contact with the stringers, so the skipper must be diligent about keeping the bilges pumped dry. The International series have a different hull (Delta Conic?), but the same problem can occur if too much water is allowed to sit in the bilge.
Ironically, it is fresh water, not salt, that causes the problem, so it is actually a bigger concern with boats in freshwater than in saltwater.
Even though I'm not a fan of the "Euro" look of the Internationals, they are considered by many to be one of the best boats ever made.
