454 crusader backfires qt 2200 rpm
I have 91 and my Port engine wont throttle past 2200 in gear without backfiring and dropping rpm. It gets to high rpms fine in neutral. I am changing caps and rotors tomorrow. Any other ideas?
while your changing cap and rotor make sure the mechanical advance snaps back if you twist it and let go. if not or it hangs up then your advance isnt operating as it should and the timing will be off or nonexistant
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
- alexander38
Good thoughts on both. If it still backfires check fuel pump and if its a Q- jet check filter in the carb
sehord
My Stbd engine is doing the same thing... 2200 Rpm I get a loud rapid popping sound..... I thought it was a rod or lifter knocking but now I think it is a backfire/pop... But I am not loosing any rpm after, I am just getting the popping at 2200 and up.... We ran some tranny fluid down the quadrajet to see if I had some carbon to break free but no avail.... wires and rotors are next in my book too.... did you ever find your problem?
