F32 back deck
F32 back deck
Am looking for someone who is parting out a f32. need the removable fiberglass section of the back deck . mine is soft and would like to try and replace it rather then try to fix it. I Will also check with Bob
Bob was selling some parts of a F32 so you may get lucky .
BTW fixing it is not that hard I had to do it on my F30 . I fliped it over cut the lower glass and removed the core . I replaced it with plywood and reglassed the lower part back on .
- alexander38
even if you find used ones they'll most likely will need work.....repairing yours seems to be a dollar wise move..
- ready123
Re: F32 back deck
Fixing is easy.. do it from underneath, you can use plywood or balsa core.Eddie-o wrote:Am looking for someone who is parting out a f32. need the removable fiberglass section of the back deck . mine is soft and would like to try and replace it rather then try to fix it. I Will also check with Bob
- ready123
I thought a picture might add to the suggestion.prowlersfish wrote:Didn't someone say that ?
Or use Divincyl and never worry about doing it again. Its a bit more expensive than plywood, but doesn't rot!
I've used it with good result s in several areas - you can even glass over the top, sand and paint for a smooth, gel-coat-like finish.
- ready123
Re: back deck
Nothing more on that part but the pulpit was done the same way with Plywood and weights to ensure a good bond before replacing the bottom glass layer, this method allowed for the gel & non skid finish of the top surface to be left untouched...Eddie-o wrote:Ready 123 Thanks for the picture if you have more i would like to see them
The fore and side decks were done with balsa core....
http://www.flickr.com/photos/trojanf32/ ... 792002787/
- alexander38
pictures are worth a 1,000 words...of
- alexander38
I looked for this Divincyl, I give, what is it....rossjo wrote:Or use Divincyl and never worry about doing it again. Its a bit more expensive than plywood, but doesn't rot!
Divinycellalexander38 wrote:I looked for this Divincyl, I give, what is it....rossjo wrote:Or use Divincyl and never worry about doing it again. Its a bit more expensive than plywood, but doesn't rot!
http://www.diabgroup.com/europe/products/e_prods_2.html
http://www.boardlady.com/softdeckanalysis.htm
