Has anyone had any problem with your gas tanks venting right? I get down to just under half full when my engines cut out. I check the fuel pumps and there not getting gas. If i put more gas in the tanks then it will start running again.
F32 Gas Tank Vents
willietrojan
Fuel Pick UP
In most cases when a tank is built with fittings for both main engines and a generator, the suction tube for the engines go right to the bottom of the tank but the generator tube only extends between 1/2 & 3/4 of the way. This is to prevent your generator from using all the your fuel and leaving you stranded.
Could your engine(s) be connected to the wrong suction tube?
Hope This Helps
Cruise Control
Hope This Helps
Cruise Control
willietrojan
Thanks for the reply, but I do not have a Gen, I have taken out the pickup tubes from both tanks to make sure that there is gas in them, they
are just uder half full. I have also taken of the connection to the carb and when I start the engine there is no gas coming the fuel pump, but I do feel the pump moving air.
willietrojan
are just under half full. I have also taken off the connection to the carb and when I start the engine there is no gas coming the fuel pump, but I do feel the pump moving air.
