F26 Poor Mans Boat Air Conditioner
vabeach1234
Post by vabeach1234 »
Well I just couldn't bring myself to pay $1600 on air conditioning for my 1972 F26 Hardtop Express. And I couldn't bring myself to cut a whole in the fiberglass to install a window unit just infront of the passenger seat like I've seen often. So here's my answer.
Parts:
Goldstar 5000 BTU window unit.
3 New Hinges
Extra cabin door from Ebay. (I didn't want to destroy the original)
Perko lockset
Painted Steel Grate (from Home Depot) to protect A/C fins
Spare pieces of wood
Screws.
http://s853.photobucket.com/albums/ab96 ... nditioner/
What do you think?
Call me cheap but I'm cool and it only takes 500 watts and 4.8 amps to run it so I can run it off the inverter while away from shore power.
Ken
wvernie
Post by wvernie »
How many watts is your inverter? I saw a Trojan in a marina in Jax. Fl. and he installed his AC in the wall beside the cabin door..I believe his was a 1976 YachtCruiser and it looked like a neat job on installing it. I think you have a good idea and saved yourself some greenstamps staying cool in the process.
vabeach1234
My inverter is the following:
The XPower Inverter 1500
http://www.xantrex.com/web/id/165/p/1/pt/29/product.asp
It's 1500 watts continuous and 3000 watts surge. I bought it at Costco for $90.00 2 years ago. I couldn't believe it was so cheap.
I need to start building a battery bank so I can run the A/C longer.
Ok your cheap . but hay it works it looks prttey good too .
nice Job !
JuiceClark
I didn't think of that
Post by JuiceClark »
Didn't think of that...mine was a lot more work:
...waiting until the neighbors were out of town
...getting in their dirty bilge - hot and dirty
...disattaching their compressors
...carrying them all the way down the seawall to my boat
...etc. etc.
Juice can I have at least 1 a/c Back ? :D and next time take the a/c out of the top not the bottom !
Sea Ya
Post by Sea Ya »
vabeach1234 wrote:My inverter is the following:
How long can you run a/c when engine is on charging the batteries? Does ithe Inverter get real hot? I have a 71' F26 I want to run a window unit. 5K BTU's I need an inverter to run the A/C when under way. Any unforseen problems? Anyone. i have 2 batteries I can get more. Any problem hooking up like 4 batteries in parralel < spelling?
72 Cutlass Jet 460 Ford (LIKWIDSUKR)
71 TroJan F26 300Hp 351Windsor ( SEA YA )
Parellel Batteries
Batteries in parallel work great for powering items,:) but the difficulty is in charging. The problem is that a charger will charge the battery with the least resistance (the best battery) and the others (the high resistance, older batetries) will suffer.:( In the end, only 1 or 2 batteries in your completely parallel setup get charged, so you don;t really get 4x with 4 in parallel.
:idea: You need a charging systems that charges each battery seapately - whihc gets expensive, because you need to use thes ebatteries in paralle, so you end up with a compelx (expensive) switching or diode based charging system..
The alternative (used for years in the telecom industry) is 48Volt DC - whihc uses 4 2 Volt betteries in Sereies. This charegs and discharges nicely with a sinlge charger - but ihas a weakness in that the whole ssytem could be come disabled if ANY of the batteries go bad (high resistance) blcoking the power or simply reducing t well below 48 volts
I've been planning a design with 2 parallel banks of 4 each 12 volts batteries in series = 2x48V Series banks ...with 48VDC solar panels to charge. Then use a surplus 48VDC > 120VAC inverter .
vabeach1234
I just wanted to bump this post. The old site that I posted the photos to doesn't exist anymore. So I added them to my photo bucket site. And I think someone on here was inquiring about cheap solutions to air condition.
FYI, the A/C that I installed has the compressor (the heavy end of the unit) on the door latch side of the door. I've seen the same air conditioner under a different name with the compressor on the hinge side of the door (basically a mirror image of my air conditioner) which would be ideal due to less moment/torque on the door hinges.
Ken
Ken the posting was under Gauges ( you know how things get side tracked)
mytrojan
Post by mytrojan »
I bought a small a/c unit for $70 at Walmart. Fits in cabin window perfect-no modification needed.
Image[/img][/list]
1971 SeaVoyager 36 "Scallywag"
1967 seavoyager
Post by 1967 seavoyager »
We have a guy that got a rooftop for a camper & put it in the bow hatch. about $650.00
seavoyager36@hotmail.com
"Restless"
guglielmo6160
Post by guglielmo6160 »
when I purchase my 71 F31 the original heat /ac unit was mounted on the wall foward of the head, and inbetween the dinette and the head. I was told this was an original unit, of course it didnt work, it was raw water fed. so for now I removed it and put in a unit. It works great , but needless to say the head is like an oven, being it vents into the head. My plan is to install a permanent marine type set up this coming spring, my setup is just to white trash for me, LOL but it does work.[img][img]http://i362.photobucket.com/albums/oo63 ... 0_0723.jpg[/img][/img]
1983 10 meter express
jathomps68
Post by jathomps68 »
mytrojan wrote:I bought a small a/c unit for $70 at Walmart. Fits in cabin window perfect-no modification needed.
Sure wasn't expensive. How effectively does it cool down your boat?
