Wher does my shower drain to?
Where? In to the bilge?
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
Mine is hooked to a pump that sends it over board , My f30 when in to the bilge and the bilge pump took care of it . if you use the shower a lot I would hook up a pump . if only rarely then you would be OK draining in to the bilge IMO.
- alexander38
O ! that's nasty. need a sump box with a pump in it and a hair filter, or a bellows type pump.
I have had boats with three different shower drain configurations:
- drain into bilge
- drain thru cockpit scuppers
-drain into pre-fab sump box which comes with a hair filter cylinder, can drain three different sinks/showers, and is powerd by a cheap Rule bilge pump.
The latter is by far the best and is readily available in common catalogs, and cheap.
Draining into the bilge causes accumulation of grease, scum, hair, soap/shampoo and stinky stuff in th bilge which is very tough to clean out.
John
- drain into bilge
John
i can see that, good pointdrjohn71a wrote:I have had boats with three different shower drain configurations:
- drain into bilge
John
my International has a large sump with a Rule 360
the question is....
HOW CAN YOU GET ALL THE WATER OUT OF THERE ?
the question is....
My experience is that you can never get all the water out. Frequent cleaning ( if you shower much), coupled with after use "flushing" with clean water keepsitfresh. Winterized by putting marine antifreeze thru drains.
When installing the sump, keep in mind the ease of cleaning. Most have clear top covers so you can monitor them. Four small Phillips head screws attach the top.
John
John
Since the sump box is located low, and the exit hose must loop up to the gunwale level before going down to just above water level, all that extra water I the line is what drains back into the sump when the pump turns off.
While generally not advisable, some ppl put a back flow preventer valve in this sump line.
John
John
- alexander38
I've found that a little simple green down the drains keeps the box clean.
no sump box in the International.
Just a simple liner that is really large and flat, with a lil 360 Rule bilge pump.
There is however a clever overflow hole that would eventually drain into the fwd bilge in the event od a failure.
That hole would also allow the fwd bilge to drain into the shower sump in the event of a rise in bilge water
but seriously, how could I get tha to get dry after use, or is it the job of a full sized terry cloth towel, followed up with spray nine?
