Deck Core Material
jjstar
Deck Core Material
Post by jjstar »
Need some idea about what material to use for deck core. I know balsa is the best, however I not forgiving if one make mistakes.
k9th
Post by k9th »
Looks like that is your first post jjstar so welcome aboard.
Welcome aboard jjstar. You're gonna get a lot of info on this forum. Bunch of helpful guys and gals here. So where you from and what do ya got?
A good alternative that won't absorb moisture or rot is Divinycell.
Image Image
Divinycell is a semi-rigid PVC foam used as a sandwich core material when strength, stiffness and low weight is desired. It has excellent insulating properties and a closed-cell structure that makes it impervious to water.
Divinycell is a rigid PVC foam with a closed, inert gas filled cellular structure. Produced in a range of densities and thicknesses to meet required specifications. Available as plain sheet, perforated or scored, as contourable scorred and scrimed backed, and as custom planks.
I've used successfully on several projects over the years.
https://www.google.com/search?q=Divincy ... 42&bih=398
aweimer
Post by aweimer »
VERY nice work! Impressive. My bow deck is in need of some repair too, been thinking about that, but it seems to be a huge task.
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
g36
Post by g36 »
aweimer wrote: My bow deck is in need of some repair too, been thinking about that, but it seems to be a huge task.
then.... it becomes how do you go about trying to try to match up the repaired area to the "trojan" non skid design of the deck. any ideas?
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
g36 wrote:then.... it becomes how do you go about trying to try to match up the repaired area to the "trojan" non skid design of the deck. any ideas?
Life is a compromise, I think colour match is more important than skid pattern because one should be happier that the repaired weak points are gone.
If the match is really a problem for you one can always redo the top gel/non skid pattern surface on the whole deck :!:
Or maybe pay a pro who can match the non skid pattern.... be thankful that Trojans are earlier than the grooved pads used in the late 80's and on which have been through many non skid pattern/score shape changes, try matching those :cry:
aweimer
Post by aweimer »
Is the finished product just gel coat or did you paint?
Aaron
1975 36' Tri Cabin
"Keep it up!"
Lake Erie, OH
jjstar
Deck Core Material
Post by jjstar »
Thanks for the welcome. I have been putting this off for a few years. I have to take care of this before i lose my deck contour. Any pros or cons on Epoxy's, vinylester, or other
aweimer wrote:Is the finished product just gel coat or did you paint?
If that is to me... gel coat applied with a stipple roller for non skid.
