I need to replace the forward drain plug & a seacock that is used for the head. They were damaged due to stray electric current. The seacock is original (1982) rubber insert with a T handle.
What's the best way to remove the old one? Once it's out, do I need to replace the plywood it was mounted on? Any other hints would be great.
Thanks,
Replacing a seacock & drain plug
ZbigK
"Time Out"
Milford, CT
1982 F32 330hp MPI Crusaders
"Time Out"
Milford, CT
Danny Bailey
The best way to remove the old one is to try to remove the threaded parts holding it in. There may be two bronze carriage bolts and a large retaining nut inside the hull. Soak them down with PB Blaster and wait 2-3 hours for it to loosen the parts. If they still will not screw apart, take your 4 1/2 " angle grinder loaded with 36 grit sandpaper and sand off the bolt heads and through hull flange that are on the outside of the hull. The whole assembly should then tap inside the hull with a hammer and punch. Yes, use new plywood....marine grade or thoroughly dried out pressure treated and install it with plenty of 5200. Use a new bronze through hull and a new bronze seacock with stainless steel ball and stem. Attach it to your boats bonding system if it has one.
