What is the total timing for a MIE230 (GM 305) and at what rpm should it all be in at?
Thanks!
Timing - Mercruiser MIE230
- Diverted Income
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
Re: Timing - Mercruiser MIE230
I believe it's 28 deg at 2900 rpm. If I recall, 1982 was the transition year from points to TB4 ignition, not that it matters for the advance curve in this case.
- Diverted Income
Thank you. Thats what I was looking for.
- Diverted Income
Found this info from a Merc Manual. Shows 8* initial and MAX of 26* advance for a total of 34* Their example of 19*+8*=25* is goofy though
https://uoil-public.sharepoint.com/_lay ... 9c04b20371
Its a PDF of a section on ThunderBolt IV Ignition
- Commissionpoint
8 at idle, 32-34 all in.
