Would anyone happen to know the dead rise of an F-32 and
is it tuff to remove the old transducers from the bottom so new transducers can be installed?
deadrise
Re: deadrise
My survey states 8 degrees at the transom. The surveyor was a previous F32 owner and appeared to be very knowledgeable about the F32's.
Trojan has been sold
Au Gres, Michigan
Au Gres, Michigan
Re: deadrise
don't know about f32 specific but my f28 is way different angle of deadrise transom verse mid boat. Maybe I do not understand where dead rise is measured but to mount a transducer the angle cut on adapter would be very different locations, and one would not want a transducer behind the turbulence caused by the screws. IMO
Re: deadrise
5 degrees from my spec sheet.
MUSICMAN7775
Re: deadrise
Thanks for all the info. Now I need to find out who made the factor installed transducers
and paddlewheels. I want to replace them and use the original holes for the new transducers.
Don't know size the holes are.
