OK here is my new plan!
one neg lead from the bus bar to the 1st battery then continue it, jumping across to the next two batteries. positive leads from port and starboard batteries running to two individual battery switches (will mount on the outside of the battery box with connections entering from the inside) then run from the battery switches to the new blue sea breakers inside the box (bluesea 187 circuit breaker states "provided switching and circuit protection in one device, could this eliminate the battery switch?) I would then attach the port and starboard house power leads to their respective breakers as well as the lead to my added blue sea fuse block and then run a short jumper wire from the breakers to either side of the solenoid (as seen running from old breaker in the pic on the right) I would then run from each solenoid lug to each starter on the engines (the solenoid is so I can combine the batteries if needed to start the engines). the engine grounds will be run to the bus bar. The center generator battery will supply power only to the generator so I plan on using either a battery terminal mounted fuse , one of the inline terminal block fuse or another blue sea breaker??? All battery charger leads will be replaced with 4ga as per the new charger instructions.
should the neg from the gen battery be isolated from the other batteries and common bus bar ?
should I add battery switches or is the blue sea 187 switchable breaker good enough?
Am I missing anything or does anything concern you guys? I'm am striving to have an organized, safe, PRETTY battery box!
Thank you so much for even taking the time to read this.
