Drain Plugs Chrysler 318
AwayOnBusine$$
Post by AwayOnBusine$$ »
Any one know how many and where are they located, been told there is 5 only found two.
Thanks Ken
F32 Fly 1975
The Dog House
Re: Drain Plugs Chrysler 318
Post by The Dog House »
My 318 has two on the engine block and two on the exhaust manifolds (1 per manifold). There is one on each side of the engine block just above the oil pan not too far back from the front of the engine. The drain plugs on the exhaust manifolds are in the center of the manifold at the bottom.
AwayOnBusine$$
Found a second one on the manifold at the rear, so 3 per side.
Thanks Ken
F32 Fly 1975
The riser has one per riser as well, at least the 90 degree turn riser.
AwayOnBusine$$
That's the one, six per side.
thanks
F32 Fly 1975
Don't know why you're inquiring but if it's for winterizing for example, check if the tranny oil cooler has one.
my tranny oil cooler does not have one, I know some of the old paragons might as they had a water jacket.
Depends on vintage. Both tranny and engine oil coolers where applicable could have plugs.
