Use of Trim Tabs
The Dog House
Use of Trim Tabs
Post by The Dog House »
I currently start to plane with my trim tabs up and then lower the trim tabs to help get my F26 out of the hole. Would it be better to start with the trim tabs down? Are there any disadvantages to starting with the trim tabs down? The F26 with the Chrysler 318 (225 hp) is definitely underpowered and needs to have the trim tabs down in order to plane efficiently. How are other F25 and F26 owners using their trim tabs?
bjanakos
Re: Use of Trim Tabs
Post by bjanakos »
I use mine to level me out when already up on plane. It makes the boat sit in the water level for better handling and allowing the props to be at a more efficient running angle. Otherwise, I don't think they are designed to get you on plane, rather than level you out once you get there.
todd brinkerhoff
Post by todd brinkerhoff »
I definitely use mine early to aid me on getting on plane quickly. I ease back as I reach plane and level out. I'm definitely stern heavy.
If you are plodding along at 1500 RPM (8k) or slower, keep them up.
When you want to accelerate, put the tabs full down. As you advance the throttle to about 2000 RPM that will try to push the stern up and bow down as soon as you accelerate. That will help you get on plane (barely) at the lowest RPM, and maintain visibility over the bow - you will will probably be doing 10-12 knots at that RPM with tabs full down. As you accelerate beyond that speed, you can start bringing the tabs up. You can actually feel when the boat rides the most 'free' based on tab position for a given RPM. Too much tab and the boat runs slower, and has more bow steer (less control). Too little tab and you lose speed and could fall off plane as the stern drops, and have trouble with visibility from a lower station with the bow so high.
Important point : it takes a boat a second or three to respond to changes in input. Don't just mash the trim tab controls... When you want to adjust, give it a tap for 1/8th of a second to a half second, and WAIT 1-3 seconds for the boat to respond. It takes a while for the boat to respond to changes (in trim, throttle, steering, etc... this is not a car on pavement, it's a boat on water....). Then decide if you need more adjustment or not.
Tabman
Post by Tabman »
Trim Tabs can certainly be used to get the boat on plane faster. Think of them like flaps on aircraft and lower them before take off! This will also result in less bow rise and strain on the running gear as well.
Tom
Bennett Marine
Tabman wrote:Trim Tabs can certainly be used to get the boat on plane faster. Think of them like flaps on aircraft and lower them before take off! This will also result in less bow rise and strain on the running gear as well.
Tom
Bennett Marine
+1
The tabs on my F-26 are always about half way down while getting up on plane and if the boat is loaded heavy in the cockpit their all of the way down. Once on plane I bring them up to find the "sweet spot" for the attitude of the boat and level ride side to side. An easy way to find the "sweet spot" is to make minor adjustments up or down to the tabs while watching the speed on your GPS. For example, once on plane I'll set the throttle at 3400 rpm and my speed will be 18 mph. I'll then bump the tabs up a bit at a time until the boat hits 20 mph. The rpms will also increase to 3500 without touching the throttle because I've also removed some of the load from the engine by setting the boat in its proper attitude.
Also, in a following sea I`ll often cruise with the tabs up and lots of throttle. This keeps the stern planted firmly in the water enhancing control.
