Just started to install the filler pcs for the swim platform, the one that I restored off the boat was stright across and I want it to curve with the back of the boat, so to the lumber yard for some 5/4 teak Boy I do love to make my self work but it is worth it.
I can see spring and water
I have to ride by my little Seascape every day on the way to work, She keeps calling out to me as I ride by “ Rick Rick get on board†“ oh don’t forget the beer†that is my girl LOL. Most all the snow is gone now with the 65 deg day we had yesterday . I cant wait to pull the shrink wrap and start working. I am going to add that el fuel pump as soon as I get on her, I know that someone done this is there a size i should get to handle the flow of gas this tank needs?
Info@emaltd.com
Info@emaltd.com
- TADTOOMUCH
Floscans
Are Floscans hard to install on a 1978 F-32 with twin Chrysler 360's. I just got a Raymarine C-120 display and would love to send floscan data to the C-120 and use the floscan gauge.
No...
The plumbing goes right in after the filters. Then you run the wiring to the gauge. I have the twin scan, which reads and and totalizes both engines and is resettable.
Top off my tanks at 220 gallons. Keep a running total on fuel burn. If I burn 100 gallons in a given time, I know I have 120 gallons left!
http://www.floscan.com/html/blue/series ... 14&catid=2
Thanks I think that will help, just want to make sure that I get a large enough pump.
Flybrige and cold beer OUCH
I cant even get on my boat yet
Info@emaltd.com
Info@emaltd.com
All the snow is gone around my boat, the water should be in the basin within a few weeks and I will be floating. I fond the Holly marine electric fuel pump that should deliver the fuel needed to run that little 351FI engin and will be installing it in about two weeks. That is when I will be taking off the covers and removing the dust from the good old gal and get her ready. I wish I was in a warmer climate like most of you guys on this forum but some of us have to be in the cold and snow
It make it that much more exciting when you put back in after a long cold winter.
Info@emaltd.com
Info@emaltd.com
