Rebedding Hatch
The Dog House
Rebedding Hatch
Post by The Dog House »
I'm rebedding the hatch on my boat. I have the hatch out of the boat and the safety glass out of the frame. The previous owner used aquarium silicone sealant to try to seal the safety glass. :roll: I removed most of the silicone sealant but there is still a thin film left on the safety glass. How should I remove the thin film of silicone? Can I sand it off? Would acetone work? Thanks for any recommendations.
Re: Rebedding Hatch
If its real glass razor blade and maybe acetone
The Dog House
Re: Rebedding Hatch
It's real glass. I got as much off as I could with the razor blade. I'll try some acetone and see if that will get the last of it. I want to make sure I get it all off. I don't want to do all of this work for nothing. Thanks for the help.
Re: Rebedding Hatch
Mr. Clean magic eraser?
The cured silicone is impervious to just about everything. Not supposed to use silicone to seal gasoline lines, so that is a hint.
The Dog House
Re: Rebedding Hatch
The razor blades, Mr. Clean Magic Eraser, and acetone got the job done. The glass is now clean and ready to be re-installed. Once I get the frame clean I'll re-install the glass using Dow Corning 795 adhesive sealant. Thanks for the help.
