windshield washers - mid cabin
Does anyone have any knowledge about the winshield washers? I don't see them referenced in the manual and at this point, they're a complete mystery.
I have three nozzles on the deck right in front of the windshield. They don't work.
I assume they're tied into the fresh water system but where? Is there a separate pump?
There's a small rectangular access panel in the middle of the cabin ceiling which I haven't removed. Does this have anything to do with it?
It's not exactly #1 one on my list but I would like to get these working. Obviously they haven't been winterized for as long as they've been out of commission. I just bought the boat late this year.
I had a feeling that panel was part of it-thanks.
I'll pull that off and check it out.
They are standard on the International.
They are plumbed into the fresh water system and as I recall, I don't think it's a motor driven pump, but it is an on/off solenoid that allows the pressure from the fresh water system to push the fresh water through the three nozzels.
Anothjer std item on the Internationals is the red lights above the electrical panel that are operated by a microswitch when the doors are opened.
These were innovative boat features when first introduced in the early 1980's.
Do you mean your electric sliding doors on your model style?RWS wrote:They are standard on the International.
Sherman
'90 10m Midcabin
'90 10m Midcabin
On my 1980 F-36 they were piped up to the freshwater system through an electric solenoid behind the fridge. I say were because I did away with the tie in to the freshwater system. Never used the things...if I operate from the lower helm its going to be raining buckets anyway. Why have the potential leak?
No, the electrical panel doors have the red light illumination. The switch is on the access panel hinged door.S.A.M. wrote:Do you mean your electric sliding doors on your model style?RWS wrote:They are standard on the International.
On th eexpress cruiser this panel is below the helm.
It appears that these features were standard equipment only during a few model years.
It's commonly referred to as the BEAN COUNTER EFFECT"
Mine also has a factory installed high water level bilge alarm. I do not know if that was an option or included in the base price.
Re: windshield washers - mid cabin
Bob,
My 11 meter had a soleniod size pump under the sink (behind a side panel)
Follow the clear plastic tubing. Mine was a bitch to locate.
Good luck
Patrick
Note: the pump was a little larger than a D-Cell battery !
Good luck
Patrick
Trojan 11 Meter International (87)
New Twin MP 502's 8.2
Westerbeke 5KW
Oceanside Harbor San Diego
Westerbeke 5KW
thanks for posting this. I removed the panel and could...
only see the 3 nozzles and the hoses going to each. No pump visible so I knew it had to be somewhere. I'll hunt around when it gets a little warmer.
These must all be bad because there's no way they're getting winterized unless
1) they work and...
2) you remember to hit the "wash" button to run anti-freeze through the nozzles.
I did discover that whoever installed the horn drove one of the screws right through the power wires.
On my mid cabin, the horns are right in front of the washer nozzles.
1) they work and...
