"New" Trojan Owner
The 42 Sea Voyager is planked with 7/8" Phillipine Mahogany. On my 36 I'm using Honduras Mahogany. It's a better wood & easier to get. Look at M.L. Condon in White Plains, N.Y. http://www.condonlumber.com. Frames are white oak.
seavoyager36@hotmail.com
"Restless"
"Restless"
MTP: Good advice, I'll check with my insurance co.
Zippy: Thanx for the info, I'll probably touch base with you again when I get ready to start on it. Ignition spares and fuel filters are are already on my list.
Rod: a) Mine doesn't have a swim platform, b) if it did, I'm not sure I'd trust it with that much weight and c) I'm not sure how you'd lash the drums to the platform as their tops would be well below the aft deck. Anyway, it's a moot point because I realized that I have a cousin who lives in SE Missouri and would be happy to deliver a 100 or so gallons to me at a point about half way to Memphis.
Prowler: Actually, I started this "extra fuel" discussion, so we're still on-topic, but thanx for being diligent. Anyway, the previous owner says that on the Ohio & Miss there's enough current that I could run on one engine at a time at @ 1500 rpm, make about 10-12kph and still get @ 13-14 mpg.
I'm gonna do the mid-way refuel thing anyway, just to be safe.
I've been monitoring the river reports for the Ohio & Miss and they're both at or near flood stage right now. I hope that changes before we get there, 'cause while I would mind the help from faster currents, there will be lots of floating debris and the high water could make tieing up for the night pretty dicey.
Hey Zippy: Did your boat come with the built-in heater and A/C units? If so, how reliable/effective are they? I'm mostly concerned with the heaters right now because we'll have to anchor or tie up to the bank for 3 or 4 nights on the northern part of the trip and over-nigh temps in that area average in the low 40s. I don't really want to run the gen overnight because a) I hesitate to trust it, b) they're noisy and c) it uses fuel. I also know that running the heaters on dc all night would probably drain the batteries.
I'm seriously considering buying an indoor propane heater. Anybody have any thoughts on or experience with these units? I'm aware that propane heaters can produce HSO2 but monitors for that gas cost more than the damned heater? I'm wondering if I could run one of the engine compartment vent fans overnight without depleting the batteries?
We boat on the upper Miississippi where fuel docks for recreation are never more than about 50mi apart. However, in the early spring and late fall, over 1/2 seem to be closed. Most "farm co-op's" will deliver fuel in this case. I do some research on the phone #s and locations of them along your route, just in case. Most of them along the river know good places to meet up as well.
As for the barge traffic, if you are courteous boater, they will have no problems with you. Have a marine radio (portable if there is not one mounted) and a good set of binoculars along. Tug's are clearly named, often with the Capt's name on the oustide of the wheel house. They monitor channel 16 and communicate with the locks on 14. If you are navigating around a barge in a tight spot on the river, just hail the tug and let the capt'n know of your intention to pass port or starboard. I have an idea that most will reply with good remarks about your classic boat as you pass. In the past 30 years on the upper Mississippi I've only ran into a couple with bad attitudes and they were caused by dumb boaters that didn't respect their space.
One other thing about the barges, stay at least 20 yds away from the tug as you pass. They have an incredible under-tow along the sides that will suck you towards them if you get any closer. Also, don't ever be straight down stream where if you lost power, you;d be in their path. People often forget it takes them up to 1/2 mile to stop when fully loaded.
Have fun. Keep us posted...
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
1994 Scout 15'
1981 16' Hobicat
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
That's actually the type of heater I was considering. I think I may not have been clear enough in my original post. I should have said that I was thinking of getting a propane heater(s) that was designed for small indoor spaces (venting not required). The reason for asking about the blowers was because I had read in a couple of places that propane heaters can malfunction and produce deadly hydrogen-sulfide gas -- easily detectable by its "rotten egg" smell but you might not smell it if you were sleeping.
Current Fleet:
* "Rivendell" - 1967 Sea Voyager 42' woody
* "Up The Creek" - 6' wood dinghy - leaky hull - no paddles
Nice boat. It's in overall great shape for it's age. The interior of yours is strikingly VERy similar to mine. I have the same appliances but mine have been taped and re-painted black for a more updated look. You should re-paint yours as well. Doesn't matter the color but just to get rid of the 60's brown and make a old appliance look new.
The rest of the boat looks like it's a GREAT start and won't need too much other than a little sanding and refinishing on some good wood.
Congrats on a great purchase.
79' Carver 28' Mariner
the bad thing about hso2 when the ppm gets above the smell it'll drop you like a rock. And any gas heater in a gas boat, safe ?
Prowler: Don't I wish it was 13-14mpg -- I meant to type "mph." LOL
jwrape: Thanx, not a bad idea about the appliances although I do kinda like the "retro" look of the brown. BTW that's a mighty pretty ride you've got, yourself.
Current Fleet:
Re: "New" Trojan Owner
I am about to transport a sister boat. Any idea how the cockpit top comes off? -Mark-GruntzenGrones wrote:Hi All:
I just bought a 1967 42' Sea Voyager with Ford 427s. She's structurally and mechanically sound (per the survey) but needs a good bit of exterior cosmetic work. I didn't particuarly want a project boat, but the price was right and I wanted a live-aboard boat. Anybody know of anything in particular I should be prepared for? I'm a newbie, so all advice is appreciated.
Here's a pic with the top removed for repairs.
[/img]
