Bay Window F26
Rodman
Bay Window F26
Post by Rodman »
My F26 has a bay window in the front, Its a one piece 33-1/4 H 82-1/4 wide. I want to replace it. I was wondering if anyone knew how thick the Plexiglas is? I wanted to replace it with a sheet of ACRYLIC TRANSPARENT GLAZING Maybe a off smoke color, for a tent look. Any ideals on this? Reason I wanted to know how thick it is I want to have the new sheet ready to go in when I remove the old one.
Trojan
Danny Bailey
Post by Danny Bailey »
Have you cosidered tinting the glass (easiest method) or filling in the hole and glassing over it (eliminate leaks forever)
Rodman
Post by Rodman »
Danny Bailey wrote:Have you considered tinting the glass (easiest method) or filling in the hole and glassing over it (eliminate leaks forever)
I would not want to glass over the whole window. Its a beautiful look out of it in the galley when you are below.
Trojan
Drill a hole in it and measure it you can seal up the hole untill you replace it.
Rodman
Post by Rodman »
prowlersfish wrote:Drill a hole in it and measure it you can seal up the hole untill you replace it.
good thinking
Trojan
turtlem1969
Post by turtlem1969 »
just be careful drilling the hole, have had plexy shatter several times while trying to drill it.
Put tape on it and drill through that.
