prop size and speed f 32
My Friend just has his maiden voyage in his 81 f 32 318's
At 3000 rpms he was going 13 mph with 16 x16 in props
does that seam rite ?
My F32 came with 16x15 3 blades.
I believe he should be nearer 20/22 mph at those revs.
Did he play with the trim tab settings?
F32's like to run trimmed down somewhat.
Of course there are many things at work here to give different readings:
Clean bottom
accurate tachs
heavy or light loading of boat.
engine power
Clean bottom
accurate tachs
engine power
mine is a 78 f32 with 318's and like ready i have 16x15 3 blade props. at 3000 at i am right around 21mph playing with the tabs sometimes a little fatster just depends on the water,wind and me, but within the 20-22 mph range that ready posted
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
I just found out he has 360s 250hps, does ur boat have gen set . just to see if the weight is about the same. He told me also he may have went over a sand bar and bent the props but is not surecaptainmaniac wrote:With my Chrysler 360s I run 16x16 cupped 3 blades, and at that RPM I get about 18-21 knots (depending on wave conditions and wind direction).
He is trying to get a apples to apples comparison
9
Yes, I have a genny as well. One other difference may be tankage - I have the original 60us gallon tanks (total 120gallons). Trojan offered 120gallons as standard, but also had the option of adding another 100 gallons of fuel capacity. If he has those tanks as well (and they are full), he could be carrying another 1000lbs.
I assume he has trim tabs and knows how to use them? If not, poor trim and really bad weight distribution (or waterlogged hull) can also make it tough for him to get on plane, which could result in that speed as well.
My friend has taken out the trim tab pump of his F-32 to replace it but while he is waiting on parts he still runs 17kts at 3000rpm without trim tabs. It takes him a little longer to get up on a plane but then he throttles back and stays on a plane and runs right with me. Him and I ran together yesterday for a 20 mile run up the Columbia River. It's a kick in the pants to run side by side with another F-32. It gives me a chance to compare performance.
1975 F-32 "SIMPLY BLESSED"
So the props are right for that power.9rock wrote:I just found out he has 360s 250hps, does ur boat have gen set . just to see if the weight is about the same. He told me also he may have went over a sand bar and bent the props but is not surecaptainmaniac wrote:With my Chrysler 360s I run 16x16 cupped 3 blades, and at that RPM I get about 18-21 knots (depending on wave conditions and wind direction).
9
Still seems to be running slow for those revs...
bob wilkins
- TADTOOMUCH
I have chrysler 360 at 250 HP turnimg 16x16 cupped 3 blades and get 22 kts at 3000 rpms in moderate seas. Is he sure his tachs are right? What is his WOT rpm?
Boat Name: A TAD TOO MUCH
Tuck
i'm not sure exactly of what size, etc, props i have on my 77 f32...i assume they're the original specs. i do know i have chrylser 318s (1045 hours on each) i also know i have one prop (starboard) with a slight ding in it, but nothing too bad (had it checked last week...going to be having it redone sometime soon).
with that said, with a good night last night...smooth water with little/no wind, i decided to get some of the fuzz off of the bottom and ran the engines up to 3100 to 3200 rpm. with that, i played with the trim and got it up to a gps speed of about 19.5-19.9 mph.
is that about right?
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
Terran
(former 1977 F-32)
Sounds about right... depends on load, if it were light and clean bottom I would expect a little more, closer to 22 mph with a good engine.
I would be happy with what you got though, certainly not poor results!
