OIL CHANGE VIA DIP STICK
Hi all,
Following my question about reading the dip stick, brings me to another subject,,,,changing the oil.
I was planning on getting an oil changer that goes down the dip stick tube,,,,,but if the engine is slanted downward, how can I be sure I get all the old oil out of the pan?
How do some of you change your oil. I can't see any way to get under the engine to get to the oil plug.
Do anyone of you use the oil dip stick tube to remove the oil? And what are your results. What brand of extractor is best?
Thanks for any info.
Larry
Larry
I have tried drill mounted extraction pumps and small hand pumps, and found them to be a royal pain in the butt..
I use the Pela extractor (see the PL-650 here http://www.pelaproducts.com/description.htm). I get 4-5 litres (quarts) with the extractor, plus what I get with the filter. That means there is about 1 (or less) that I don't get, but when I add new oil the one, the old (bad) stuff is less than <20% of the total volume, so not that big a deal. Get engine hot, poke the extractor tube down the dipstick tube, give the cylinder 20-30 pumps. Then just wait for it. I actually have the extractor tube marked at the right depth (I use the dipstick to gauge where to mark it so it's about 1" below the surface of the oil) to start extraction, then when it starts sucking air I push it in a bit more, and repeat the process until it stops sucking. If you push too much down right off the bat, because of the curve the hose will take on when you coil it between uses, you run the risk for the hose to go into the oil and back out.
The only better alternative I have seen is a bolt on kit (not sure who makes it), where you pull your oil plug and replace it with a fitting. The fitting then has a tube that runs from it, out to the edge of the engine, and up to some bulkhead. In other words, it's like a dipstick tube but starts right at the drain plug. Then you can hook up any extraction / suction system you want and know you are sucking oil from the lowest point in the pan.
Larry,
A) I use a oil extraction system on my F32's diesels.
B) On my 26 (trailer queen), I use a hose that replaces the drain plug. Its about 2' long, and I snake it out the 1" bilge drain plug and pull its brass cap off to drain into a jug. This is very easy.
You can do as in "A" above, or add the hose in "B", and simply hook an extraction system to it (to avoid having to use the fill tube which doesn't get all of the oil out).
These guys market a reasonably priced system for oil extraction, through the drain plug.
http://www.danamarineproducts.com/OilRemoval.htm
My Cummins have the hose to the drain plug with hand pumps mounted on the side of the engine. This is an accessory option from Cummins.
On my 440's I used a brass hand oil pump but I would remove the dipstick tube so I could use one size larger suction tube, and so I could turn the tube to the deepest part of the pan and get the most oil out. Works best while oil is warm...can't hold onto pump if oil is at full operating temp.
I'm with you wowzer. I have never found a brand of hand pump/vacuum style extractor that can compare to the 12 volt pump mounted on top of a pail. They work so much faster. Change out the pail for a 20 litre (5 gallon) one, and I can do my two big blocks and the trannys litterally in a matter of minutes. More expensive way to go but time is money and play time is precious.
I use a vacuum pump type extractor from west marine.....slow but works fine......Some oil remains but that will be the case with any dip stick type extractor............John
1998 Kawasaki ZXi 1100
Big D wrote:I'm with you wowzer. I have never found a brand of hand pump/vacuum style extractor that can compare to the 12 volt pump mounted on top of a pail. They work so much faster. Change out the pail for a 20 litre (5 gallon) one, and I can do my two big blocks and the trannys litterally in a matter of minutes. More expensive way to go but time is money and play time is precious.
That's what I use (surflo) and have hose on my drain plugs I can get 14 qts of oil out in about 2 mins maybe less , thats warm oil not hot . IMO thats the only way to go .
