trojan 40' fly -year 1980 - some questions
Hi, just registered in your forum.
I've tried to find something in the web and in your forum fr my topics, but no results, unluckly.
I've the possibility to buy a 40' fly age 1980 equipped with 2 x 275 hp GM diesel engines. Since I need to find a compromise betwen speed and fuel consumption (here we pay about 6 USD per 1 US gallon of diesel fuel!), I would know, if anyone of you have a real direct experience, the fuel consumption of this boat at the cruise speed (which is ?) and at full throttle (which is the max speed ?).
For what I know, the engines should be GM 6-71 or 6V-71 turbocharged.
The fuel tank is declared about 400 US gallons.
Which is the displacement of the boat ? At first impression it seems built with thick hull without economy and so quite heavy (at least for the european standards where a 40' fly weights about 9 or 10 metric tons).
Always about the hull, any experience of osmosis problems after a certain period ?
really many thanks and regards to everybody
Federico
Federico
Federico,
I have a boat test article from a November 1978 Motor Boating and Sailing magazine that shows a top end speed of 17.5 knots while burning 31.2 gph. The F-40 had what Trojan called a "Dual Mode" hull and could travel at trawler speeds or planing speeds. In displacement mode it burned just 4.3 gph at 7.3 knots. It looks like best cruise speed is about 1600 rpm, 8.6 knots while burning 9.8 gph. The article notes that their test boat was hull #1 and is up to 3,000 pounds heavier than future boats and may have been propped wrong. Trojan expected to get 4 mph better speed across the rpm range. The test boat had GM 6-71N's and weighed an estimated 27,000 pounds. It holds 445 gallons of fuel. Can anybody tell me if there is a way to post a pdf file to the forum? I'd be happy to post the article or send an e-mail to anybody who is interested.
Brent
Brent
Brent, really many thanks!! Great job.
You solved all my questions in only one shot.
Yes, it will be interesting see the article: my email is fpuccetti@gmail.com
Does the indicated burning rate refer to both the engines as total, doesn't it (hopefully...) ?
Again thank you.
Again thank you.
Federico
I have a 1983 40 aft cabin. with a clean bottom and running gear at wide open throttle I have briefly seen 17K. Mine has J&T Detroit 6-71Ns rated at 310hp and I normally cruise at a power setting of 1850 - 1900 rpm. That gives me a cruise of 8-10kts depending on conditions. The fuel burn figure that I use for planning is 10-12GPH again depending on conditions and use of the Gen set. On a long trip I can set it up at 16-1700rpm and get 8kts and 8GPH. Fuel load on the boat is 445Gal. 160Gal on each side tank and 125Gal in the Aft. The Water tank is also 125Gal. All this being said: When I am just curising around locally I run with 1/2 fuel 1/2 water and average 8-10 knots and 8-10 gallon per hour. It's and outstanding strong well founded boat. good luck
Han
Han
