aftermarket fuel injection
Anyone install an aftermarket fuel injection system on their crusader or mercruiser 454. I have a buddy that installed a FAST fuel injection system on his '67 Chevelle with a chevy 454, which was installed on the original manifold. The project took about 3 hours, and required the installation of a fuel return. Very dummy proof. The technology and ease of installation has come a long way.
Anyway, he's had the system on for about 2 months and says that it was the best money he ever spent. The reliability and power increase are incredible. The motor starts right up and it has no hesitation even when cold. The system continues to adjust to the motor.
Just wondering if anyone has installed one on a boat application and what the results have been.
My motors have about 700 hours, so it may be a bit before I repower with something cool like a turbo diesel or a new shiny 8.1 gasser.
I'm with Paul, you will not reap enough benefit from the amount of money you put out.
Could that be from improper installation? The technology has come a long way, and you no longer have to have a computer engineering degree to hook them up. Its hard for me to believe a properly set up and calibrated fuel injection system would produce less power and less efficient fuel burn than a 20 year old carb, I wonder if a marine application, with weight and rpm makes the difference. My friend with his BB 454 couldn't be happier. Of course, it in a car.
"properly set up and calibrated fuel" yes thats a key , I the people I know that tried and where not happy knew what they where doing ( Pros). A good FI system will use 02 sensors to control fuel . not to easy to set up with a marine exhaust , also marine FI engine may have cams that are set up for FI . the fuel has to be right on a marine engine to rich you burn fuel too lean you burn valves and pistons . Many of these kits are kind of fit all and that means it sort of fitts '
====================================Stripermann2 wrote:I'm with Paul, you will not reap enough benefit from the amount of money you put out.
DITTO THAT
keep the quadrajets !
Make them right and you'll be fine
SERIOUSLY!
