"Spinning the Engines"?
I want to see if these LM383's are still able to spin free. They have been sitting un-started for 3 years. To avoid scoring the cyl walls, etc, my plan was to remove the plugs and spray a small amount of either fogging oil or marvel mystery oil into each cylinder, cover the engine with a large old towel then spin the engines without any compression to get that top cylinder lube evenly distributed. Since the engines have been sitting in the same position for three years they may not want to move easily at first. Anyone have any feedback on this whole approach? Thanks Guys. Steve
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
Hey guys can you prime a mopar by spinning the oil pump like on a bowtie ? If he can is do it along with the other things he plans on doing , I would turn them by hand first.
I would crank by hand first. Check the plugs when you pull them, may be worth replacing them anyway. Then I'd make sure my battery cable connections at the starters are clean and tight. They haven't run in a while so do a visual on wiring, ign. components (cap, rotor etc). You'll have other issues to consider such as the condition of the carbs, fuel etc., and check timing too, and I don't mean just base timing, check total advance too. Change engine and tranny fluids. Make sure they're pumping water and keep a close eye on the temps. We're all keeping our fingers crossed.
Thanks guys! Manual cranking it is!. I will NOT be actually trying to start the engines at this time. I have way too much work to do on the fuel tanks and delivery systems. My goal right now is to make sure the engines will spin free and to coat the cyl walls with some light weight lube. Will let you all know. Thanks
Steve (risctaker)
Steve (risctaker)
aka "Basket Case"
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
I would definately put Marvel Mystery oil in each cylinder now. This way when you're ready to hand crack it, the oil will have helped to free the piston if they're stuck (hopefully) !
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
' Goomar '
If want to pressurize your oil system you can do so with a bug sprayer; plumb the wond of the sprayer into an oil galley (remove oil sending unit if it's in an easy place to get to). Then pump up the srayer and squeeze the wond (like you're spraying) keep pumping until you get oil to the top of the valve train and you're good to go.
Oh and use a new sprayer that you have cleaned first.
Steve
Steve
