Paint stripper
Struts and Rudders
Paint stripper
Post by Struts and Rudders »
Hello all,
Were stripping paint around the boat and wanted to point out that aircraft paint stripper is by FAR the best product we have found to strip paint.
The brand we are using works great. It is thick enough to use on vertical surfaces and makes the paint fall off...really!
Cleans up with water will not burn or ignite due to vapors.
Just sharing....
SRD
What brand are you using ?
Struts and Rudders
I am using Klean Strip brand
They have a full line of products.
I get mine at the local O Reilly's.
Really good stuff and less expensive than more well know brands.
SRD
F36
foofer b
Post by foofer b »
I used that on my dinghy's bottom paint and it softened up even the hardest thirty year old paint.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
Struts and Rudders
Hello all,
One thing I will say is that this stuff is not easy on gelcoat.
Please be cautious and keep a nice wet rag around to wipe off any excess stripper that gets in contact with your gelcoat.
SRD
F36
koviak
Post by koviak »
Did you use this on bottom paint ? Don't want to pay for sodablasting if this works.
Dennis
1989 10 Meter Mid-Cabin
Struts and Rudders
Lake Norman. Soda blasting will do it for $35 per foot and do an awesome job.
Look him up on the web...it is worth the call for a quote.
Ron Bergman is his name.
The paint stripper is not cheap..$12 or so a quart.
SRD
foofer b
Post by foofer b »
Soda blasting is the way to go. Took three coats of paint stripper and much putty knifing to get to the "sand away the rest of the paint stained gelcoat" stage.
MY CURRENT FLEET
