Best Spark plugs for 270 Crusaders
AndyF32
Post by AndyF32 »
I have 1990 Crusaders that need the plugs and wires replaced. Looking for opinions on which plugs run best in these engines.
Thanks
AC plugs work best in GM engines
MR43T AC Delco. Marine spark plug. Don't use automotive plugs. The threaded casing will rust and could break off in cylinder head. Seen it many times...
Stripermann2 wrote:MR43T AC Delco. Marine spark plug. Don't use automotive plugs. The threaded casing will rust and could break off in cylinder head. Seen it many times...
X2 -
AndyF32
Post by AndyF32 »
Thanks! Gap is .030 I assume. Any preference on wires?
Try Crusader part number, 97454 for the wires.
AndyF32
Post by AndyF32 »
Thanks for all the info. I think I will spray some penetrating oil on the plugs that are in there now before I try to remove them. I was not aware of that corrosion issue with some plugs.
