Debate Question
rbcool
Debate Question
Post by rbcool »
Do you check your oil with the engines running or not?? I've heard alot of different theroies :roll:
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Engines no . the trans you run it then shut it down and check it right away. the goes for velvet drives and ZF done warm-hot.
jddens
Post by jddens »
I check engine oil non-running and cold......never heard of checking engine oil running, auto trans is cars yes......engines no...John
1998 Kawasaki ZXi 1100
Engines, no. Engine off and preferrably level.
Ron, tell those people you're talking to...to put the crack-pipe down. :wink:
k9th
Post by k9th »
I check mine cold and not running.
wowzer52
Post by wowzer52 »
Wow, :roll:
1975 F-32 "SIMPLY BLESSED"
wowzer52
Post by wowzer52 »
rbcool, I think someone is yanking your chain. I swizzle my wife once in a while but never about the running gear, it's too important.
rbcool
Post by rbcool »
I've heard alot of debate over this. I took my Saturn to the dealership a few weeks ago and the mechanic told me should be checked when warm and running
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
There is no debate engine oil engine off car or boat. thats a fact no debate. if the told you that about engine oil run and run fast.
Now that we know your talking about a car the trans is checked differently
On your Saturn you check the auto transmission oil/fld running when hot. Different then your boat.
risctaker
Post by risctaker »
Be sure to have the winter air changed in all your tires as well...
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
Not sure you can even check the oil with the engine running. Think somone is pulling your chain.
I used to have an admin assistant whom we told to "rotate the air in her tires". She came in one day and said she tried, but couldn't rotate the air, so she just let the air out of all 4 tires and the re-inflated them. Ouch! ;-)
You should check an automatic transmission with the engine/trans warm (drive it several blocks) ...
When a customer call and says they have a flat tire, I reply, I bet it's only flat on the bottom...and they say, yeah! Here's your sign.... :roll:
Talked to a couple of friends who are currently GM and Ford dealer techs and they confirm checking oil with engine off on thier product. Also have searched the internet re the Saturn and I couldn't find anything on oil check with engine running.
Allen Sr
Post by Allen Sr »
Whoever made that statement needs a rubber room! Never heard of such BS in my life to check engine oil with it running! :roll: :roll: :roll: :roll:
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Should add to your tires with them rolling for equal distribution!
:lol:
