got it
???? Was this about the 273 engine ? I was tring to find some info but no real luck But I do remember a few things about them . Let me know if you need to know anything I can remember .It is in the 318 (LM ) famly.
good deal bud. the race is on LOLtrojanmanXS wrote:yes the question was if the 273 and 318 bolt pattern to the stringers was the same as I didnt want to let this engine pass, knew it was smaller? but dont really care about the topspeed as much as finding a good deal that got my boat on the water this year in stead of next m thanks
- alexander38
you looking for a 318 ? LH or RH I might have one , I've the engine just have to confirm which way it spins..
Most likely the same . But you can always swap the mounts .trojanmanXS wrote:yes the question was if the 273 and 318 bolt pattern to the stringers was the same as I didnt want to let this engine pass, knew it was smaller? but dont really care about the topspeed as much as finding a good deal that got my boat on the water this year in stead of next m thanks
What area you in ? Tonys engine maybe worth checking into .
http://www.marinepartssource.com/chryslerpb/6874pb.asp
Apparently the 273 is the same engine desing, Marysville marine has parts book thru 1974 showing it as 273/318/360.
They are what was once Chrysler Marine.
